Repair guides and support for your LG TV.
Left side is too dark. How to fix it?
Hello,
I got a LG 42LG5000 TV in 02/2009. In 02/2011 (just after the TV's warranty expired), when I opened the TV to watch something, I saw that the left side of TV was much more darker than the right side.
As manufacturer and repairers say "left LCD panel is gone, replacement price is much more then TV's price, so throw the TV to trash" but I'm not convinced actually because of the following;
Till a month ago, when I shake the TV or wait a little bit, the left side was coming back to normal but in last month, it doesn't.
I'm attaching the pictures. So you can see the problem and may give some advice to me.
http://www.zpnd.com/tv/DSCF7073.JPG
http://www.zpnd.com/tv/IMG_0753.JPG
http://www.zpnd.com/tv/IMG_0754.JPG
Thank you.
Score 15
13 Comments
hi there tim,this isn't really an answer as such ,its just i have the exact same problem and i am wondering wether you actually got your lcd set fixed at all? and how you actually acheived the repair,any info would be appreciated. yours faithfully larry!
by
Hi Tim;
Have you solved the problem?
by
my tvs right side is pitch black. how do i fix?
by
what do i do if my screens lighter not darker but its also the left side??
by
Have you tried applying pressure to the screen cables on the driver boards. or you could always try the simple method.
https://youtu.be/_KsGoE8ehnY
or if you dont mind spending alittle time on it :)
https://www.youtube.com/watch?v=DnESRpt-...
by
Show 8 more comments
Add a comment
Chosen Solution
Tim, sounds to me like the backlight inverter is going out. You want to definitely check on fuses or continuity of voltage supply lines going to the X Board/s, (your case check the X Board) as well as the LVDS cable. Replace blown fuses, connect broken lines, and resolder loose solders. Check on the capacitors on your boards, they may be either loose or popped. Look for any leakage on the boards (looks like a oily sticky substance) and check the top of the capacitors. they should be flat. Any bulging indicates a failed capacitor, The older LG's have the backlight inverter power separate from the power supply, and in that case you will require a new LCD Panel. Very costly, if you can even find somebody who has them for sale. The newer LG's have the inverter connected to the power board. In that case you could try to fix it by replacing the power board. It would be great if besides the model number you could find the Chassis number. It might be possible to get a service manual for you and give you some more specific details for your TV. Hope this gets you started in the right direction. Good Luck.
Score 5
2 Comments:
The right side of my screen does this everytime i move the display for cleaning, etc. Power cycling the TV has always fixed it so far. I'm guessing there​ is some loose wire, or poor connection.
by
I was playing hot wheels on my ps4 and in the settings for the game some how i was able to fix mine
by
Add a comment
Most Helpful Answer
https://m.youtube.com/watch?v=_KsGoE8ehn...
This actually fixed my TV. Was going to get rid of the TV so thought I'd give it a go and it worked :) finally can watch a full screen again!
Score 6
5 Comments:
Well this freakin works! Although I modified it and used my hands and clapped them together fairly hard on the front and back of the left hand corner. That immediately fixed my problem! Plus no scratches or damage to the TV like hitting it with a rolling pin would do LOL!
by
I have a Samsung. The right side goes dark ao just flickers. I took the back off and placed some rubber weather stripping at the top to add pressure . Reolaced the back and WALA, the picture is as good as new. I don't know if this will work on all brands of tvs. Fred
by
Same here but I do not know to fix it
by
Unbelievable. It did work! But I tapped it mildly. Not as hard as the guy.
by
I thought it was a joke. I had exactly the same issue with my LG. I was about to throw it anyway because it was annoying. I hit it 4 times in the top left corner with both my hand and the corner in between. It actually worked, I'm speechless...
by
Add a comment
i have the same problem, but my lg is fix now .
this problem is due of connection betuine lcd (the last point of left up )panal and lvds bord.
a little presson in this point the lvds signal will be ok .
1.u can open the bac of the lcd tv.
2.desassambl the front of the tv.
3. desassambl the front of the lcd panal .
4. the first group of wayer in the left must have more pression.
sorry i have a bad english
good luk
Score 3
3 Comments:
correct
answer
by
I had the same problem with the right side of my Sanyo TV I unplugged it not shut it off but unplugged it for one or two minutes and it came back and it's working fine sense
by
This aint work for me
by
Add a comment
I had the same problem but i have a DELL, i could not work out why suddenly the right side of the screen was all dark, then i thought the lightnings gone, then i thought its not the screen as all the pixels are still working behind it, so then i went to the older problem that when i was a kid it was common problem the power lead/cable, that is plugged into the back of the monitor, the fuse might of gone or something to do with the power not going right into the screen happened a lot 18 years ago but this is less common recently, so the power cable is not working right and thus creating a problem with the monitor just like when a power supply is old and is just hanging in there to keep your pc running while you upgrade parts inside the pc it will cut of so i changed the cable that powers the screen and it worked no more dark side, i can not explain why this happens, but ide suggest its a old problem with power leads or cables pluged in to what ever devise has to work right anyway thats how i got mine to fix simple get a new lead just that plug it in and turn it on i hope it was of help.
Score 2
2 Comments:
We have same issue, but we have a Sanyo 40 inch flat screen T.V. I take very good care of my TV have never had an issue with it until the other day,When I turned it on... The left side was darker than the right side of the TV. Any suggestions and what we can do for a SANYO flat screen TV with same exact issues but left side is darker than the right side.. any help would be very greatly appreciated, I'm on disability with very little money and I cannot afford to replace this or to pay anything really to get it fixed... Thank you so very much I appreciate any help....Sincerely Tonya Z
by
Thanks for your help saved me time and money for so simple of an explanation!!!
by
Add a comment
LG 55UH6150 backlight LED replacement
Score 2
1 Comment:
Yo I appreciate you posting the step by step tutorial above! To you or whoever the author is if it wasn't you, well done and again appreciated!! You ever find yourself in Las Vegas the first round of beer on me! Cheers
by
Add a comment
my first idea, the origin of the problem is a bad solder somewhere on the (power) board or a back light unit(inverter)(or light(defective))
Score 1
Add a comment
Add your answer
Tim will be eternally grateful.
Past 24 Hours: 13
Past 7 Days: 122
Past 30 Days: 679
All Time: 358,553
